inez 4/6 drop on 4x4
Anyone install this kit on a crew cab 4x4. Looking for pics and wheel sizes before i take the plunge
Just a heads up,it will add a bit of wear and tear to your CV's.Not sure how much you use it as a 4X4,but just letting you know the axles will wear a bit more,and you're milege might take a drop.When you drop a 4X4 that much,the CV's start absorbing horsepower to turn,and that translates into usually losing a smidge of milege.You can't run a CV on a sharp angle with-out it taking more power to turn,basic law of physics
R/T_Fire
Pleasant Grove
Ive been looking for pictures of a kit installed on a 4x4. I want to see how it all aligns up and how the strut mounts..
May sound odd, but I am thinking of using these and modifying them slightly for my coilover adventure.. I may make a end link that uses the strut mount as a connection for the swaybar..
But need to verify the width of the on how it mounts to the frame and get a visual on it
Check with Matt Fikac at Moes. Don't quote on this,but i think you can buy coilovers for the 2 wheel drives now. If you're going radical on the front suspension,i wonder if you'd be better off starting out with a 4X4 frame,a week-end and a couple evenings work should swap a frame,as i think it pays 40 or so hours by the book
Kraftei
Stony Plain
I bought a 2016 Ram 1500 4wd with 12,000kms, it came with the Ground Force Lowering Kit 2/3. I removed the kit at 13,000kms and lifted the truck. The kit seemed to work well, ride quality was stiffer then stock imo.
If you're still trying to sell the Ground Force kit,post it up on BertaRams and Badlands Rams on facebook,you should get some interest there
Midnight Storm
One Badass Ram
Victoria, B.C Canada
