Inside door / headliner moulding
Mr Mog
West Jordan, UT
Afternoon all,
The rubber door/headliner moulding on both sides (driver/pass) on my rear doors is sagging. Doesn't catch if I push it back up, just sags back down. Imagine this may be a result of the 3rd brake light leak which I already fixed. Any suggestions or tricks you guys have found for this? I'd prefer to not remove the entire moulding to replace it, or glob a bunch of unnecessary adhesive/etc in there when it seems like what should be an easy fix.
Thanks ahead of time
SitKneelBend
St. Louis
3.6 Pentastar
Afternoon all,
Remove the c and b pillars and drop the headliner to inspect. It's possible your roof antenna is leaking so you can start on the driver's side.
Mr Mog
Mr Mog
West Jordan, UT
Hey thanks for the reply. I should've been more specific. There is no further leaking at all, the entire headliner is dry. Just the upper middle section of the rubber moulding above both rear sides of the back seat sags like in the pics. If I push it up, it doesn't "snap" into place. Didnt know if there was some trick I'm missing or what.
14 Lonestar
Have you tried squeezing the moulding together where it should grab? If it is spread apart it will not hold.
If you use pliars,wrap the jaws of the pliars with black tape/electrical tape first,otherwise they might leave tracks on the molding
