Installing LED Bed lights= Question
salmonbum
Dryden\Ludington, MI - Steamboat, CO
Hey guys, I want to install some bed lights on my 2015 RAM and came across this mopar accessory: Ram 1500 Bed Lights (Part No: 82210928AB)
I do not want to get this kit because I am using some waterproof LED strip lighting I install on boats. But I like the way its hooked up to power.
The ad says its only good for 09-12 trucks. If you look at the instructions, it shows how they get power with some wires under the A pillar which are for the dome light. This route, the bed lights would turn on when you unlock the truck or turn dome light on. I like this Idea. I removed my A pillar and the wiring colors and location that are called out on instructions do not match.
Anyone have any idea on which wires I could tap into now?
CF_Smith
Canada
HEMI 5.7
The bed lights that come in the 2016's are tapped into the cargo light. So when the doors unlock, they light up with them, and they can also be turned on with the switch.
JGBimle
I really like that idea
DougM55
I think tying into the cargo light would be best so you can use the cab switch to turn them on at will.
sbarron
Wasilla, Alaska
tied mine into the cargo light wires (WT/TN - if I remember correctly), under the drivers side rear door sill.
MoreOvalteenPlz
Stillwater, OK
Tapped into the cargo light wire for mine. I bet you could tap into the cargo light on the trailer harness and save some wire.
salmonbum
salmonbum
I am unaware of a cargo light wire that goes into the 7 way??? I know there is a constant 12v (red), but I want to stay away from using that of at all possible. If a wire comes loose back there and grounds out, you would kill the 12v to trailer when towing (that I need). I have herad the 3rd Gen didn't use fuses, but some type of reset in the computer that required trip to dealer. Guy here at work delt with it a bunch and ended up bypassing the stock wiring and installed is own just for the above reason.
Either way cargo or dome (which they may boh come on when I use the keyFOB) I need to know which wire in under apillar is the correct one to tap. If its true there is a cargo wire anywhere under the bed ot use, can you supply location?
MoreOvalteenPlz
Stillwater, OK
I think I'm confusing the cargo wire with the reverse wire on the trailer harness as I have tapped into it before, my apologies for the confusion. I tapped into the cargo light wire (WT/TAN) under the drivers side front door sill and went through the E brake grommet and followed stock wiring back and went up behind the taillight and into the bed.
salmonbum
salmonbum
You have a 2103, mine is a 2015. I'm not sure the wiring is the same?
rango10
Has anyone figured out what wire to tap into? I also have a 2015 and want to tie the bed lights into the cargo light wire
lukedukem
Victoria, Tx
what you can do is remove the cargo light assembly and see what color wires are there and which color provides power when lit up using volt meter, then remove the door sill on the driver side rear, its part of the wire harness, tap into it just under the driver side rear passenger sill. you can then run it how you want to the bed.
Luke
Nanuk
NEW JERSEY
2011 RAM 1500 Big Horn Crew Cab
If you pull the door sill plate and find the wire harness , grab a test light and poke each wire while turning on and off the cargo light ... when the Test Light fluctuates on and off simultaneously with the switch BINGO you found it .... Option 2 is get a good outdoor switch and mount it under the gunnel of the bed , wire it 12v and your able to operate without getting in your truck..... Option 3 if you have a cap wire it direct with 12 v from Trailer wiring and they sell a switch that mounts to your cap rear glass strut that will allow the lights to turn on and off when you open the rear glass , almost like a factory install ... Worried about leaving the glass open while fishing or loading / unloading , throw a switch in between the power source after the window light switch , now you can leave the glass open and lights will remain off .. Hope this helps
07MegaCabRam
Chandler, Arizona
6.7L CTD
When I did this on my truck, I just looked at the switch on the dash and noted the color of the wire. Then went to the passenger rear door, pulled the sill off, found that wire and tapped into it right there.
Was really easy. You can get better lights for 70% less than those Mopar lights. I got mine off of Amazon for $30 for both sides.
stars80
Trying to wire the LED strip lighting in the cargo bed. Wondering how or where you ran the wire to tap into the cargo light wire. Did you come in thru the front fire wall and under the carpet some how. I think the door sill panel just pops off but some of the other panels by the driver front pedals I'm not so sure about. Last thing I'm worried about is drawing to much current from the cargo wire and popping something, There was talk somewhere about the new 2016 trucks detecting to much current being drawn and shutting off the power supply thru the computer. Not sure if that is true?? The draw is about 4.8W/metre, so running about 12 ft of LED lights would be just under 20 watts. Any help would be appreciated..thanks
Administrator
If your looking to do something like this:
These are waterproof LED light strips with adhesive backing stuck to the underside of the bed rail. I tapped the power from the 7pin trailer harness 12V and have a switch in the bed just for both sides out of harm's way near the tailgate.
savage99ss
Tennessee
2012 Ram 2500
Tapped my led strip light to the 7 pin connector. I think it was the red wire. Continuous power.
MaizeNBlue
Just did this.... didn't want a switch in the cab, going back and forth to turn on and off seemed like a hassel... got a kit with a switch to install in the bed..... wired them directly to the battery. ..simple
d21arren
2019- Rebel
I just did mine over the weekend, 2014 express. The wire that I tapped into was white with a tan stripe and was found under the rear drivers side sill in the wire harness. This is the cargo light wire. I ran my wiring through an existing plastic plug that is under the backseat carpeting and grounded out to the metal in the same location.
