Interior Front Map/ Dome Lights Won't Shut Off
Goose55
Ajo, AZ
Cummins High Output 6.7L
All of a sudden I have an issue with my 2019 Ram 3500 front dome lights. They used to automatically turn off after putting the truck in gear, but now remain on. This is particularly bad at night, keeping the interior brightly lit, affecting visibility through the side windows.
Early this morning, while still pitch dark, after parking, the lights remained on for several minutes after all other vehicle lights shut off. They are supposed to dim after exterior lights go off, and then shut off
Anyone else had this issue?
Thanks!
Goose55
Goose55
Ajo, AZ
Have you checked the dimmer knob setting?
I played around with the 2 dimmer knobs but got nowhere. I then discovered some switch buttons up on the upper console that I had never studied before and finally got this corrected. How it ever got messed up is beyond me. TO MUCH technology !! Whatever happened to simplicity?
CharlieUpNorth
Idaho
6.4 L Gas
What "Switch Buttons up on the upper console" are you talking about? I have the same problem, but have not found the buttons you are referring to.
Goose55
Goose55
Ajo, AZ
The cabin light switches above the windshield rear view mirror. I seldom if ever use them.
