interior light not staying on - AlphaOBD?
DReinke
Camdenton, MO
My son has a problem with his 2006 Ram interior lights. He would like to find a way to keep the interior lights on when he is loading or unloading goods. If he opens the door, the lights come on. about 15 seconds later the lights turn off. Not enough time to load the groceries. If he manually turns the lights on with the switch, the same thing happens. Is there a way to adjust the time the lights stay on? I understand there is a desire to turn them off to prevent battery drain but I hope there is a way to extend the time the lights stay on. He does have AlphaOBD so if there are codes that can be changed, he can connect to the truck and change the codes in the BCM or ???
Ftank
