JDE117
Hi All, I have been using this forum pretty heavily as a non-member to gain knowledge about my purchase, and now that the deal is done, I figured I would join. This is the first valuable vehicle I have owned; prior to this I was leasing trucks.
I just purchased this used 2015 Ram 2500 Power Wagon with 94000 miles and it is in stellar condition. Mild paint chipping on the rocker panels and the very beginnings of surface rust near the front of the panels, all of which I plan to fix. Other than that, immaculate. What I would like to know is what do you suggest I do next in terms of preventative maintenance on the vehicle? I see that some guys here are changing the Dif oil or doing a half-trans fluid change but could that cause more problems to arise? This is the first time I have owned a truck like this and I would like to keep it in tip-top shape. If you were me, what would be the first steps you would take with your used truck?
Side note: According to the Carfax, the truck has its transmission and driveline serviced at 78k in late 2019 and the suspension and steering system serviced at 82k in early 2020.
Thank you all in advance for your help.
