K&N Dusting my engine?
Discussion in 'Engine & Performance' started by PCT, Jan 10, 2017.
Sponsored By: Moe's Performance
  1. PCT
    PCT Senior Member
    22
    1,576
    308
    May 9, 2014
    Northern California
    Ram Year:
    2013 Ram
    Engine:
    4.7
    Truck is going back to the dealer to check out my grinding noise in my 6nspeed. So I took out my home made intake tube, and out the original airbox back in. I Shined my led flash light down my tube and noticed dust lined the tube.... I'll take pics later. So either my tube is a bad design, or the K&N is letting small particles through... I should have my next oil tested next oil change....
    Sent from my SAMSUNG-SM-T817A using Tapatalk
  2. Gamester
    Gamester Senior Member
    446
    107
    Jun 23, 2016
    Ram Year:
    Engine:
    As long as K&N filters are properly oiled, not damaged, and installed properly; they will not let any form of dust in. There is most likely a leak in your custom tube.
  3. yoda
    yoda Senior Member
    48
    282
    94
    Jul 25, 2016
    Ram Year:
    Engine:
    The only Diesels with dusted turbos I have ever seen at the dealer, had aftermarket K&N style filters.
    Never had one yet with the OE filter.
    So either they are not maintained, installed correctly, or they flow better because they filter less dirt. I suspect the latter. This is an interesting read.
    http://www.nicoclub.com/archives/kn-vs-oem-filter.html
  4. Kotta390
    Kotta390 Senior Member
    32
    1,078
    225
    Jul 6, 2015
    Ram Year:
    Engine:
    If the K&N needs to be recharged it can allow larger particles to come through to your engine ie: dust/dirt.
  5. Hemi450hp
    Hemi450hp Preferred Vendor
    9,162
    4,008
    Jul 17, 2012
    Conroe, TX
    Ram Year:
    2011 Ram 1500
    Engine:
    This applies to all oiled filters. Too many people install these and do not clean/oil them properly which will allow dirt to get through. If properly maintained, they will filter the dirt as well as stock while still allowing better airflow.
  6. Kotta390
    32
    1,078
    225
    Jul 6, 2015
    Ram Year:
    Engine:
    Most of the time those filters are not maintained properly and also cause damage to the compressor wheel of the turbo from the oil and dust particles that come through.
  7. huntergreen
    huntergreen Senior Member
    60
    2,053
    677
    Jan 5, 2011
    Ram Year:
    Engine:
    the old KN vs paper filter debate. i stick with stock filters.
  8. PCT
    PCT Senior Member
    22
    1,576
    308
    May 9, 2014
    Northern California
    Ram Year:
    2013 Ram
    Engine:
    4.7
    I have a gas engine, the filter maybe has 15k on it, and is factory lubed.
  9. Gamester
    446
    107
    Jun 23, 2016
    Ram Year:
    Engine:
    Should be cleaning and reoiling it every engine oil change; that's what I do anyways and have never had dust in the tube.
  10. PCT
    PCT Senior Member
    22
    1,576
    308
    May 9, 2014
    Northern California
    Ram Year:
    2013 Ram
    Engine:
    4.7
    The box said every 50k, so i was going todo it at 25
Share This Page
