Just curious why you need new hubs on a 2 year old truck and why you would not use the warranty.
Exactly this. you can't run 14 wides and expect the dealer not to blame the failure on the wheels. Chances they caused the failure pretty slim since the set up only has about 200mi but again easier for me to fix it than fight till 2050 to get it done. Ended up buying trq wheel hubs with the lifetime warranty.Cuz check the wheel setup. The stealership probably won’t touch it for warranty work or make so many excuses that it would take till 2045 to get it into the shop for a warranty fix.
Actually had some noise up front I just assumed it was a warped rotor. And there is always the possibility that something wasn't right from the lift install. Does make ya wonder but that's why I opted to by the trq hubs with the lifetime warranty.but there was nothing wrong before the wheels went on......makes u wonder and more headaches down the road
