LED Bed Light
R.L.K.
Bristol , Tn.
Easy peasy!
R.L.K.
Bristol , Tn.
FYI I got power from the 7 pin trailer disconnect , RED wire constant 12 vdc , ( not through the ignition ) you can get ground from there too if you'd like the black wire directly across from the power if I remember correctly , I established a chassis ground myself in a convenient location I could use for something else in the future . The 7 pin connector is easy to disassemble for power and or ground . , I mounted my switch like the OP , I put a 1 amp in line fuse between my power wire and the switch .
And my established chassis ground .
Then I enjoyed a cold beverage .
mitch1313
i think someone on here used a magnetic switch so when the tailgate was opened the lights came on.
how do you like the G2? i was thinking of saving up to get one.
I did something similar. But using no switch. I took my power source off of the exterior cab light. Now everytime I unlock my door, the bed lights light up for 30 seconds. Push the ublock on the fob for another 30. Or if I need longer I can turn them on via tha factory cab light switch on the dash.. works great!
Steel Curtain
Gambrills, MD
2015 Ram 2500
Well I guess this will be another project planned for the truck....Looks sweet guys and thanks for the pics and info for wire tapping. We go camping a lot and lights in the bed will be super helpful.
Metalizer
Pearland
For the price of materials and simple wiring....This is a great additional for anyone that has a cover.
Been looking for something like this since I installed my TonnoPro hard fold cover months ago
bubbasneed
Cincinnati OH
I just bought some LED lights and switch to do this. I installed a Bak Fiber Max cover on the truck and I can't see anything under that cover.
crash_eco
Canada
hemi
thats a great idea, last time i unloaded a bunch of crap out of the truck i popped open the cover so the rear light could be used. May have to pick up a couple lights and tap into the worklight.
R.L.K.
Bristol , Tn.
Used mine this past weekend for Deer hunting , it worked perfectly , this is my Bow case @ 5 AM , and the 2nd pictures are the results of my am deer hunt !
No Bruiser , but a good meat management Doe , and my bed lights worked perfectly for my application. .
Barcelo5
Niagara Falls, Ontario
Hemi 5.7 6 speed with mds
Where did you source the cargo light wire?
R.L.K.
Bristol , Tn.
Okay , what exactly do you mean when you say source the wire ?
Do you want to know where I bought it ?
Or where I got power from ?
SitKneelBend
St. Louis
3.6 Pentastar
Where did you get power from for me (I think that's what he meant too).
Sent from my HTC One using Tapatalk
R.L.K.
Bristol , Tn.
I got power from the 7 pin trailer lights disconnect. You can get ground from there as well . I opted to establish a chassis ground for other reasons .
This wire is a constant hot 12vdc. I installed a 2 amp in line fuse btween here and the switch installed .
Hope this helps.
SitKneelBend
St. Louis
3.6 Pentastar
It does thanks.
Specifically though, we were looking for where Mitch sourced the cargo light power so we could power them using factory switches.
CF_Smith
Canada
HEMI 5.7
These look very cool. I love the lights that come on the 2016's, though I'm concerned they may get smashed down the road, because of where they are.
Those of you who went with the coloured LED's (that look unreal BTW), do you have any problems seeing your load at night? Like if you had red LED's and were trying to look for a red shirt etc.
gofishn
Iowa
hemi 5.7L, 345 cu in
Well I got my bed lights installed and my Bedrug bed and tailgate mat. It is all awesome and I am so glad I did it.
8315572a6b8586ac4b493979f96c292e.jpg29cc12c330f07792ec747c41e8c9cc2e.jpgd75e96af13bc573ab1c8978dafd7a0d2.jpg
Clean Install.
NEver even knew the had a bed rug tailgate mat
looks liek I have to do RESEARCH@!!!!!
