Led reverse lights
Steel1996
North eastern US
2019 ram with halogen reverse lights. Trying to find led’s that fit. Everything I’ve purchased off Amazon that says it fits, does not!
Administrator
@Steel1996 is the '19 a Gen5 (DT body) or Gen4 (DS body) truck?
S
Steel1996
North eastern US
I e only tried the ones I ordered from Amazon. They say they fit but they don’t plug into the base. I have a gen 5. If you have purchased some that fit, please let me know.
danielmid
Southeast WI
2015 Sport 4x4
Diode Dynamics are what I run in the taillights, and add on led pods in the rear bumper.
DA67Goatman
Ohio USA
I've also tried Precision LED and Diode Dynamics both are good quality.
1 MEAN66
Waterford NY
Hemi 5.7 VVT-MDS
Morimoto "Boost Bar License Plate Light" part #R138702. Lights up and I mean LIGHTS UP 50 ft. behind the truck and about25 feet wide. I got mine from "American Truck" Was under $80 when I got it. When the trailer is hooked up (because of where it mounts, can see it. You will not notice it there until go put it in reverse. Comes with waterproof led long enough to hook to factory harness under the bed.
2021Ram3500
Gray's Harbor WA
Pull your taillights out and look at the number on the bulb before you try to order any new bulbs. Ram is known for using different bulbs then listed in the manual or even on websites. I ran into this problem several times until I was told about this from a local Ram dealer! I had to return several bulbs that would not work until I found out about this problem.
Orca
