LED Taillights
JetFixr
NW Florida
I found a set of LED factory taillights from a 2014 Ram and I was wondering if I could install these in a 2018 Ram. Mine didn’t come with the LED taillights. Do I need to do any modifications? Any help would be appreciated
Black-Wolf
North Carolina
They are the same generation, you should be able to do this w/o issue. The only thing you'll need to do is if your original TLs are incandescent, you'll need to use AlphaOBD and OBDLink MX+ to turn off the "Tail Light Out" message from the information center. There are posts here on how to do that - just search for AlphaOBD.
Cableman
Longisland
I believe you will need an adapter, factory led trucks have different plug vs non led trucks.
G-Ride990
Administrator
Administrator
Chandler, AZ
There are a few companies that make adaptor harnesses.
EagleChief
Oklahoma
2014 Big Horn
