Lifted the Power Wagon
Txhillbilly
2012 Dodge PowerWagon
We spent the last couple days lifting the truck. I used the Rancho 4" kit,and put some 35" Cooper STT's on the factory wheels.
The Pitman arm must have been put on by King Kong,the guy's broke 3 Pitman arm removing tools,and 2 impact sockets getting the factory arm off the gear box.
Then when we tried to install the new control arms,we find out that Dodge changed the bolt size and they are too big to go through the bushing sleeves.
So after talking to Rancho,I decided to take the sleeves to a machine shop and have them drilled out so the bolts will fit.
I already knew the drivers side exhaust will have to be modified to clear the front driveshaft,so that wasn't a surprise.
The rear end was the biggest surprise. The rear skid plate crossmember will need to be modified before the truck goes off-road. The driveshaft barely clears it setting on the ground,so I'll have to cut out the center section of the crossmember,and then weld in a driveshaft loop to ensure the driveshaft won't get damaged,and the crossmember is still functional.
Then after installing the rear blocks,and setting the truck back on all four tires,I notice that the rear is a whole lot higher than the front-2.5" higher.
So now,I will have to either replace the blocks with lower ones,or take out all of the short stack leafs that Dodge uses for a lift block on the Power Wagons.
The photo in the Rancho instructions shows the block is installed under these,so that was the way we did it.
I'm not trying to put down Rancho in any way,but they need to stay on top of any changes that the mfg's do to each year of vehicle that they sell lift kits for,and then include those changes in their kits.
Anyway,I love the way the truck looks and drives.The ride is a little firmer than stock,and the tire do make a little noise on the highway,but not too much. As soon as I can get the few things modified,I'll take it out for some dirt/mud testing,if we ever get any rain.
Before-
After-
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Looking good. Now I'm ready to see some offroad pics.
Sagebrush2500
2013 2500 Big Horn
Excellent. The only thing better than a Powerwagon is a LIFTED Powerwagon.
WhiteExpress
Midland, TX
Looks great! The back end really does look SUPER tall. Hope ya get that figured out.
I sold a lot of Rancho suspensions, I've installed a few, I've never been real impressed with their attention to details.
T
Txhillbilly
I've used Rancho products since the early 80's,along with many other brands.I have never had any major problems with any of them. There will always be problems with changes from the truck mfg's from year to year that don't get changed in the aftermarket kits,but then the aftermarket companies need to step-up and make the changes to their products,and notify the buying public via their websites,that if you purchase part#XYZ then contact them for any upgrades/changed parts.
This would be very helpful for both parties involved.
The rearend height is a simple fix,but the crossmember issue wasn't even brought up in the Rancho instructions,and the photo's in the instructions are definitely not a Power Wagon,or it would show the skid plates/crossmembers,as all of these trucks come with them as part of that factory package.
It'll take me a couple hours under the truck to solve these small issues,and then I'll be happy as a 5yr old in a mud puddle
Ftank
