Lighting bolt crank no start
cathyclarke798
Richlands, NC
Replaced fuel pump, throttle body,crank sensor,cam sensor and brand new battery. No codes. Any idea what next. Was driving great then went limp . Towed home. Please help
jws123
nj
Did you confirm you have good fuel pressure even tho its a new pump? Truck will still start with a bad alternator ect does it even try to start do you hear it kick at all?spray some starting fluid down the intake see what happens. If it runs a second you have a fuel issue also a compresison test is a good idea aswell.
Burla
2010 Hemi Reg Cab 4x4
Was lightening bolt yellow or red?
Burla
Plug in your code reader.
