Loose tow mirror at the pivot point
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
Is there a way to tighten the tow mirrors in a 2011 Crew cab? My mirror is nearly flopping around because where it pivots and can be folded is very loose.
Sent from my XT1635-01 using Tapatalk
02blkram47
02blkram47
Lebanon, NH
No one has any idea if these are fixable?
BWL
Embrace the skeptisism
BC Canada
There's a thread on the cummins forum that can walk you through it with pictures, but it's not an easy fix.
02blkram47
02blkram47
Lebanon, NH
Oh hell no..I just found the thread, no way i'm doing that. looks like i'm buying a new mirror. Thanks for the info.
Reactions: BWL
BWL
BC Canada
Don't blame you. I felt the same way. Got lucky and found a used one in good shape for 100 bucks.
rsdata
N Ky
2014 BigHorn 1500 8spd 4X4
my small tow mirror is also floppy... I took a piece of flat foam rubber sliced a little thicker than the distance between glass and outer edge... then wedged it in to hold the mirror in place... the foam I used was from a piece of insulation It is about 4 inches wide and maybe an inch deep shoved into the mirror body.
02blkram47
02blkram47
Lebanon, NH
Good idea, only the place where my mirror is floppy is where it pivots to pull it in towards the window. Right at the joint. The glass is totally fine.
