Ole Buck
I joined the the masses when I redone my engine and went with a 180 t-stat over the recommended factory one. I have only about 2 thousand miles so far and I intermittently get an bank 2 operating in lower level code. From what I I have gathered it’s the south end 02 sensor or lower sensor giving a reading of the cat that the pcm is not happy with. It’s new cats both sides and all new Mopar sensors. Could it be caused by the engine not getting to proper operating temps therefore causing the fuel to combust improperly or at the right temps and not getting a clean burn?
