Lowering fix.
TriSum
SoCal
EcoDiesel
Sean, saw on your site that you do lowering kits also. Why don't you guys put something together to let these newer (09-14) Ram's go to a 4-6. Maybe a spindle that keeps the track width correct and a solution for the rear notch and arm bracketry.
David
Maxtrac Suspension
Anaheim, CA
4.7L V8
Hey thank you for the suggestion we appreciate that! As of right now we offer a 2/3" drop for the 2009-2013 Ram 1500 2wd trucks. We are working on doing a 2" drop spindle for the front which will fit 2002-2013 but we have not discussed doing anything to drop the rear more on the 09-13 models. We are working on a 5" rear drop for the 2002-2008 models though. I will let the guys know about your suggestion though and maybe in the future we will offer a bigger drop than our current 2"/3" kit. Thanks again!
TriSum
TriSum
SoCal
EcoDiesel
Kits are already out for the older trucks, no one has anything for the new trucks.
Innovate, don't follow.
David
Maxtrac Suspension
Anaheim, CA
4.7L V8
We definitely appreciate your suggestion and it is something that we have discussed, but it's not in the works as of right now. We have been getting calls almost daily for about the past 18 months for the '02-'08 models looking for drop kits. Due to the high volume of calls and requests for us to make a kit for that year span is our next venture. If we start to see more customers interested in the 4th gen drop kits (such as yourself) then we will definitely look into designing more kits for them. Thank you again, we appreciate your input and feedback!
Maxtrac Suspension
Anaheim, CA
4.7L V8
Is your 2/3 kit compatible with a '14 quad cab 4x4?
Unfortunately it's not. Our lowering kit is only designed for the 2009-2014 Ram 1500 2 Wheel Drive models. The 4wd has a strut front end while the 2wd has a coil spring. Thank you for your interest though!
Lowrider357
