MAF sensor info
Outdoorsman390
I have a 12 outdoorsman and have a airaid could air intake and throttle body spacer. I just put on a BBK throttle body its bin a week and the check engine lights came on. Took it to dealership and they said that its a high flow code because of the amount of air its getting. They said that it mite figer it out and it may go alway. But does anyone know if their is a performance or dummy Mass air flow sensor I can get and see if that will trick the computer into thinking its normal.
jwheeler
Washington
You will have a hard time finding a mass airflow sensor for your truck. Do you know the code number?
Tach_tech
5.7L HEMI
Your truck doesn't have a MAF sensor. As jwheeler said, if you have the actual code we can help.
