Jhill
What is required for a manual swap?
If no one has any info I will post the info once I figure it out lol
Sorry I should have been more clear my question is towards what do I do with my pcm/Tcm communication. Can my pcm be flashed as manual?Flywheel
Clutch and pressure plate
Throwout bearing
Bellhousing
Transmission
Shifter assembly
Clutch master cylinder
Clutch hydraulic lines
Pedal assembly
Possibly a new driveshaft
Possibly a different cross member
If 4x4,Possibly a different transfer case and both driveshafts
I'm probably forgetting some stuff
