Maxtrac Suspension at Got Exhaust
Nick@GotExhaust
Preferred Vendor
SC
MaxTrac Suspension was founded in 2010 by a group of truck enthusiasts who share the same passion for building quality suspension products while keeping them affordable. The main aspect that sets MaxTrac Suspension apart from other suspension manufacturers is that they provide three types of suspension product lines; Lifting, Leveling, and Lowering. The cornerstone of MaxTrac Suspension's systems is their spindles, which are made from either ductile-iron or forged aluminum and provide a precise amount of lift or lowering, without compromising ride quality or suspension travel. With their ultra-durable, bullet-proof products, ride height options, and affordability.
Product Lines:
Lift Kits
Leveling Kits
Lowering Kits
Suspension Components
Contact us for more information and pricing.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Description
Maxtrac Suspension, The leader in 2WD lift technology has delivered again with another industry first Forged Aluminum upper control arms for the 2009-17 Ram 1500 2WD & 4WD platform. These arms are made from 6082 T-6 aircraft grade forged aluminum which is substantially stronger than it's billet counterpart while keeping the weight down over other steel versions. We went with factory style rubber bushings for the frame to arm which will last a lifetime and not crack or get brittle like Polyurethane and will not get loose like Heim joints. When it comes to the ball joint, We wanted to use nothing but the best and that's why we chose FK Uniballs for our arms. To complement the Uniballs we went with 17-4 high strength stainless steel Uniball adapter that is precision CNC'd and machined to exact tolerances for a perfect fit. Our arms also come with a o-ring sealed cap to keep out all the dirt and grime that can reduce the life of any Uniball. These arms are built to the factory specifications which will allow the consumer to use these arms anywhere from stock all the way up to our 7" kit and any other kit that utilizes the factory upper control arms with no issues. The big benefit with these arms is having more droop travel over stock. this equates into better ride quality and less "topping out" while going over bumps. The arms come clear anodized to last and come with our limited lifetime warranty. Remember if it doesn't say Maxtrac on it then it doesn't have our quality in it.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Contact us for a quote
CanRebel
Toronto
Why do companies that sell car parts have such horrible websites :)
Went to look on their site to see what have...
Their website links you to "Best mountain Bike"
In another COUNTRY...
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Not having that issue here...Their site is under construction still.
What are you looking for? I can assist you.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Message me for a quote and info
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
The absolute go to option for RAM 2wd lifts!
