quadrazer
- Joined
- Jun 22, 2011
- Posts
- 9
- Reaction score
- 0
- Ram Year
- 2002
- Engine
- 5.9 360 Vin Z
Greetings everyone. I've been looking at this forum for some time and I finally decided to register and post a problem I have with my 2002 Ram 2500 4x4 with a 5.9L gas V8 that has 134,000 miles on her. I sure hope someone can help me diagnose this problem, because I'm quite literally stuck on this one.
The short version of the problem is simple....the truck has a horrible idle while in park that rises and drops at random. This happens the instant you start the engine. I can feel the whole truck shake, and the rpm rolls from near stalling to 1500+rpms. When you put it in drive, it stumbles a bit while holding the brake. When you go to give it light throttle...it hesitates, surges and stumbles as it tries to get moving. If you give it a lot of throttle, it will push thru it and go. Driving between 40-50mph while holding a steady speed, the truck will buck hard, and at random. The problem is much worse when cold (meaning first start up/drive of the day) and is not as pronounced when the engine is completely warmed up, but it is still there.
The odd twist of this idle/hesitation problem (and probably the most important part of this issue) is that it clears up completely when I shift to neutral. If it's in park, it idles horrible and stumbles bad when I try to rev it. Then I put it in neutral and she idles smooth at 625rpm, and will rev normally, with no stumble at all! How is that possible?!?
I have done quite a bit work to the truck in the past 2 weeks, due to a blown plenum gasket which was eating oil and killing me on fuel. Here's what I have done so far:
New plenum and intake manifold gaskets
New distributor cap and rotor
New NGK double platinum spark plugs
New spark plug wires
When I removed the intake, I cleaned the inside of the intake very well, and pulled the IAC to clean it and the IAC port in the throttle body. The inside of the intake was filthy when I first took it apart (oil streaked all over the place), so after I had everything clean and put back together, I dumped 2/3 can of SeaFoam into the tank, put in 10 gallons of premium fuel in it, and did a vacuum injection of the remaining 1/3 can of SeaFoam directly into the intake manifold via the PCV vacuum port hose (per the can's instructions). After that tank of fuel was ran thru, I filled up full on premium fuel and have used all but 1/8th of that tank of fuel with NO change at all in the rough idle/hesitation problems. While I had the intake off, I had to remove the distributor due to a broken off distributor cap hold down bolt that happened when I tried to remove the cap. I marked the base and rotor locations prior to pulling it and lined it back up when I reinstalled it.
I am also getting 2 codes with the CEL (check engine light) on. The codes are: P0340 Camshaft Position sensor A Circuit (Bank 1), and P1341 Manufacturer Controlled Ignition or Misfire.
It should be noted that the truck is not using any oil now and the fuel milage has improved, but is not back where it should be. Sorry for being long winded, I just want to give as much info as possible to aid in diagnosis.
Any ideas or suggestions would be greatly appreciated!
Thanks,
Brian
Thanks,
Brian
