Need more lift!
STYSMason
6.7L Cummins
i just installed a set of Mantric 4.5 spindles in the front and the 3" coil kit in the rear and it sits level. I want more lift though. I see i can get new shock and lift springs for the front, but then the rear will be sagging again. What are my options?
Dantheman
South Carolina
I'm not sure but you could call and ask if the 7" kit works for the diesel. A body lift is probably going to be the best option if the 7" isn't compatible.
