I ran Camburgs on my Gen1 Tundra. They were 1" uniballs and squeaked from the day I installed them. I replaced with stainless FK uniballs (I think Camburg was using chrome plated at the time) and the squeaking stopped for a while. The bushings squeaked as well... I wrote it off for the price I paid to maximize the offroad performance of my truck.
The uniballs were exposed and allowed dirt and sand to wear at the lining and the uniballs themselves to the point where my mechanic said there was some play that prevented proper wheel alignment. These Ram UCAs use a larger uniball - if they come with a cap, it may help prevent premature wear significantly. Just remember to clean the underside of the ball cup and use some sort of dry lube on them (don't use wd40 or similar).
This is what I used:
https://camburg.com/shop/suspension/tri-flow-heim-uniball-lube/
Camburg makes great products - but like all mods, be aware of the potential downsides to them... In this case, there is a possibility of the squeaks and the introduction of a wear items (uniballs and bushings) that will need periodic attention.
