newbie..HELP
patearlley
purchased a 1997 ram 1500 5.9 gas been driving it for 2 weeks no major problems till I put it in 4 wheel drive
here is my problem driving in a straight line its drives ok bot making corners it feels like the front wheels r sliding or being pushed....help pls
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Until you put it into 4WD. Now, is the truck OUT of 4WD or are you still engaged in it?
Blucchese93
magnum 5.9
No truck is ment to take sharp turns while engaged in 4wd. It happens to everyone, its your u-joints binding
P
patearlley
Its not only sharp turns ..does it even turning around
P
patearlley
Only does it when 4 wheel drive is engaged..
All the susp looks ok it has new ball jointsthe tie rods r alittle loose
It does it so bad it stops the truck
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
That's why you don't make sharp turns in 4WD. All of our trucks do it. Unless it's misbehaving in 2WD as well, don't worry about it. It's just natural operation.
