1966ponyguy
First of all, I’m new to the forum but have owned several Dodges. My latest purchase is driving me crazy. I bought a 2004 1500 with the Hemi. When I bought it the original owner told me he had never even changed plugs. I have driven it for about 2 months now, and my daily is about 25 each way, mostly interstate. The truck has right at 150,000 miles on it and is completely original. So I noticed the front was a little loose. I replaced most of the front end (2 wheel drive) including lower ball joints, shocks, rotors, pads, sway bar links, and inner and outer tie rod ends. I also replaced the plugs, almost half of the plug tip was burnt off after 150000 miles but the truck ran perfect. I also replaced the egr valve to clear the only code showing. Since the tune up, the truck will die sometimes when I take my foot off of the gas. Not often but it is starting to get worse. I can shift up out of gear and it starts back perfect. It also runs pretty good on the interstate. Most of the time it idles dead on 600 rpm. I have also noticed that the mileage has dropped from about 15 mph to around 12.5 mph. It is still throwing the egr code even after the replacement and now it’s throwing a new code. The codes are: P0404 and P0157. Has anyone ever had or heard of anything like this. If this was an older car, I would think it is acting like a fuel problem.
