RLH21
I looked up and researched this issue haven’t found a solution,
I have a 2002 , 5.9 motor, issue is turn key to run all gauges do not move if this happens engine will crank but will not start, if I go back later or next day if I turnkey to run and if my gauges move truck will start but then die in a couple of minutes. Tried ASD relay, battery and crank sensor with no luck any help would be appreciated
