OEM 9.25ZF Limited Slip Differential - $100 OFF!!
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Just like the gears, we were able to buy in on a big order of limited slip units for the 2011-up 9.25ZF rear axle. These list at $774 direct from Dodge, Our normal selling price is $599, and while supplies last, these have now been marked down to only $499 with FREE SHIPPING!!
These units are in stock and ready to ship same day!!
Mopar Limited Slip Differential for 2011-up Ram 1500 9.25ZF Axle
Feli
will the motive 4.10 work with this lsd or only the oem will be a direct fit?
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Feli
does that lsd require maintance or is it like the Detroit trutrac that doesn't require maintenance
mondo
Columbia, Pa
2014 2wd express rcsb
I know this is an old post but didnt want to start another one. Is this and the Audurn one the only options available currently for 2011 and up? Is the Mopar one helical or clutch packs? I wish Wavetrac and Detroit trutrac would make one for these years.
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Auburn, Yukon Duragrip, and Mopar are the only 3 options. The Mopar has been the most reliable of the 3.
Your other option is to use the Detroit Trutrac, but you also have to buy a 2nd driver side axle shaft, older 9.25 gears, and an install kit to make this work. Cost for this package is about $1500.
mondo
Columbia, Pa
The mopar one uses the mopar gears only correct? If so, have you heard or experienced any failures? If so, at what HP? I know there would be variables but in general.
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Mopar will work with any 9.25ZF gear. Its not a HP rating where they fail, but wheel hop has been the biggest culprit I've seen to hurting the factory LSD.
mondo
Columbia, Pa
Figured wheel hop would be one of the variables. Which brand gear set do you recommend?
ISellRams22
TxnRamTrvlr
how do you know if you have the right axle. i have a 2018 8 speed hemi 4x4 crew cab
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
I always run OEM Mopar gears when I can. They are the quietest and most reliable.
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
All 2011-up Ram 1500 trucks have the 9.25ZF Rear Axle.
mondo
Columbia, Pa
Ill be getting in touch with you soon for the mopar lsd, 4.10 gears and install kit. :head3:
John813
So, just to (re)clarify, the 2019's(5th gen) share the exact same diff/gears?
I know you said 11 and up, just that the website only has the diff/gears under the 4th gen section
And if I buy new gears and an anti slip diff, do I need the master install kit for both? Tad green when it comes to differential work.
Mr.coon
5.7 Hemi V8
Bump
Sent from my SAMSUNG-SM-G890A using Tapatalk
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Bump
Pricing from Mopar changes constantly. These are currently $549 shipped.
Phatt
Idaho
Eco Diesel
Do you guys sell these pieces to install a TruTrac?
Orca
