OEM Brake Controller Question
tsherv
WI
Hi,
I have a 2020 Ram 1500 Big Horn (Level 1). I have the 8" touch screen and the smaller display (3.5" I believe). I purchased an OEM brake controller and installed it this afternoon. I did purchase it used off of Facebook. It did have all the proper labels on it and I know it is a factory module. I know that the brake controller sends a signal to the display on certain models. My question is this: I installed the brake controller, but i have no idea if it works. I'm assuming I need to be hooked up to a trailer for anything to work? Should I see anything in my settings on my 8" display? Just looking for a sign that the controller works. My trailer is in storage right now so I can't connect to it. Should I see anything in my displays? Should anything light up or anything like that?
Thanks.
chopperman1
2018 Rebel
5.7L HEMI
Did you program the truck for the new modules? Not just plug and play. Need to have the dealer program your truck or use something like AlfaOBD.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
FYI, the RAM IBC are hit and miss as to whether they work with certain brake types on trailers. I have had four different fifth wheel RVs, and the OEM controller worked with one of the four fairly well. The other three new Rvs with drum electric brakes... didnt work basically at all. Ended up with an aftermarket controller, with night and day results.
T
tsherv
WI
Thanks for all the info. I made an appointment at the Ram dealership to have it programmed. Looks like it will be an $85 charge.
RamOwner48420
michigan
Hi,
Thanks.
How big of job is it, start messing with dash panels? I am finding a new one on ebay motors for $70
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
DS & DT Rams may use different oem brake controllers
I have no clue about 1500 & Heavy Duty differences for OEM Brake Controllers
Mo381
Indiana
Hemi 5.7 eTorque
It is about a 30-40 minute job. You have to remove the knee/kick panel below the steering wheel and also the center radio climate control panel. There are a ton of youtube videos on the install.
Davidskywalker
San Diego
6.7 L
Do you know why?
I maybe having the same problem.
The brakes are all new on my trailer but the truck can not stop the trailer ( electric brakes).
Like what kind of electric brakes should it work on?
Something does not look right. This PWM system seems as if it’s not delivering enough current to the magnets on each wheel.
Administrator
If your trailer brakes are the typical magnetic type they should work provided they are mechanically adjusted correctly.
Follow the adjustment procedure to set the trailer brake gain correctly. Lots of people have the misconception on how the trailer brakes should work, most expect them to pull the truck back because time or inertia based brakes would do this. The OEM controller uses not only braking force but vehicle speed to determine braking force.
Davidskywalker
San Diego
6.7 L
The trailer brakes have properly adjusted (3 axles with NEW drum electrical brakes). I get NO errors from the truck regarding the brakes. I took the truck for testing and the shop is saying that the truck is NOT putting enough power when the gain is set to 10. Its only putting like 5 or 6. They have a brand new MAC tester that performs a trailer Load Simulation. Here is the link: https://www.mactools.com/products/et9107a
Electric Brake Force Meter with dynamic Load Simulation
I am not sure what kind of brakes it should work with. When I bought the truck there was NO information regarding what kind of trailers it could work with or NOT.
Davidskywalker
San Diego
6.7 L
The trailer brakes have been adjusted correctly. I took the truck a mechanic shop and they told me that the truck is NOT delivering enough power to the trailer. They used a MAC tools Electric brake force meter with load simulation, this tool shows that the truck only delivers about 5 out of 10, with the max gain on the truck set to 10. Electric Brake Force Meter with dynamic Load Simulation
BossHogg
Oakland Township, Michigan
6.7L Cummins
Do you know why?
New brakes have to be bedded before they gain stopping abilities. Trailer dealers fail to mention this and few folks read the axle owners manual that should have come with your trailer explaining the bedding process.
Take a 5th wheel RV that comes in at 15K or so, the trailer brakes will unlikely lock the wheels because of the weight on the tires. In contrast, take an unloaded utility trailer where the tires will easily lock up.
In addition to what crash mentioned, look up the definition of proportional braking.
BossHogg
6.7L Cummins
Speeds below 25MPH, the factory trailer brake controller does not send full power to the trailer's brakes. Using the manual controls, and the gain set to 100%, you should get 100% at the trailer.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
thats odd i have not had any problems with brakes on any of my rams from 2012/2014/2016 or my 2019 and pulled 4 different rv trailers with electric drum brakes using the factory controller .
18Aries
After enabling my brake controller I had zero problems with the trailer brakes. Helps a lot
JustinRam1500
