CoffeeAnderson
2015 Bighorn 5.7L 1500 here... I have the normal sound system in my truck.. how big of a difference between the normal and the premium sound system is there? Thanks!!
The stock 6 speaker system needs the speakers replaced. The 77KICK28ab (fronts) and 77KICK41 makes a huge difference and is plug-n-play, no spacers or adapters needed. You can take it a step further and put a Kicker Hideaway subwoofer under the back seat.
To upgrade to the Alpine system would be a major PIA, a lot of wiring harnesses would need to be added.
The door panels have to come off but they're fairly easy to remove, no special tools needed.do you need to take the door panels off to swap speakers im assuming?
do you need to take the door panels off to swap speakers im assuming? Also do the 77KCIK28ab and 77KICK41 have better sound quality in general? How much are they
