Oil pressure problems
Runaround
Silsbee
I have an '07 Ram with the 5.7 hemi. Today my wife started the truck and the oil pressure gauge showed 0. She shut it off, waited a while restarted the truck and now the gauge is showing to the right side of the gauge, above normal everytime we start the truck? What is the problem? If you say it is the sending unit, tell me where it is located. Thanks.
ramportin1
Sickest member here
Oregon
Front of block down about midway, it will be a open wrench style fitting with a plug connected into it
Sent from my SM-G975U using Tapatalk
Runaround
Runaround
Silsbee
Do you think this is the problem?
ramportin1
Sickest member here
Oregon
Probably
Runaround
Runaround
Silsbee
Thanks so much. I will check it out tomorrow when it is daylight outside.
ramportin1
Sickest member here
Oregon
No problem, it'll be directly above the oil filter on front [emoji1303]
Runaround
Runaround
Silsbee
I did find it but will not mess with changing it tonight. I figured it was the sending unit since the gauge went to zero with no noises and knowing the truck would have oil. It was a little bit low but not enough to cause no pressure. Thanks again.
ramportin1
Sickest member here
Oregon
No problem man, mine went haywire not to long ago, would drive then plummet to zero and truck would start chiming at me haha same truck 07 5.7. Believe it requires a deep socket if I remember correctly
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
I had the same thing happen to me a few years ago in my 2004 5.7 hemi.gauge dropped to zero,truck started chiming.i knew there was oil pressure because there was no knocking or ticking so I knew it had to be something with the gauge probably the sending unit.it is located right above the oil filter.it sends the signal to the gauge.i believe I pd. 20 bucks for the new sending unit and had it repaired in 5 min.pull the electical connection off,unscrew it,put Teflon tape on the threads of the new one,screw it back in and plug in the electrical connection.
srv1
blasdell n.y
srv1
blasdell n.y
srv1
blasdell n.y
srv1
blasdell n.y
I don't know why this posted 4 times sorry my laptop is wonky today,sorry….
Runaround
Runaround
Silsbee
I changed the sensor today and the problem is corrected but now I am wondering what the two wire sensor is that is on the side of the motor right above the oil filter, just curious and trying to learn this truck. I bought it this past January and I know so little about these Dodges. I have always been a Chevy man.
HemiLonestar
MD
Side or front? Only one I recall right above it is the cam sensor. Only ones really on the side of the engine are knock sensors. Got a pic?
Runaround
Runaround
Silsbee
The one I am referring to is about the same level as the oil pressure sensor but is pointing out towards the passenger side of the motor, right above the oil filter. I will try to get a picture.
Runaround
Runaround
Silsbee
That is the wires going to it, right in front of it. You can see the new oil pressure sending unit that I installed and the oil filter. Correction on the above statements, this sensor is just a little bit lower than the oil pressure sending unit.
HemiLonestar
MD
Oil temp. Keep forgetting that one exists since it isn't a standard gauge lol.
Ftank
