GustavoF78
I have a 2004 ram with the 4.7. I’ve had issues with the code P0344. I’ve checked the sensor and wiring. All seems okay. I get 5 bolts on the signal and voltage wires and the ground wire is good too. The sensor works as it should too. I checked it with a multimeter and by passing a piece of metal in front of the sensor and it works. The engine had been professionally rebuilt before the issue popped up. When I installed the engine it was running perfect. After a couple of days the code came up and I haven’t been able to figure out what’s the issue. Help please
