P0489-egr Control Circuit Low
Dave Flomerfelt
6.7 diesel
I have a 2007 6.7, Cummins with 110k miles, it runs good but keeps getting this code P0489-egr Control Circuit Low. A local mechanic he said it might be carbon in the catalytic converter and suggested running it hard to maybe blow out the carbon, which I have tried with no improvement. In general it has always run clean no smoke from exhaust. Also occasionally get P2089 another egr issue. I picked up a Haynes manual but it was not much help
Fuel35 67
Hanford
Take the egr off the intake horn and clean it with Purple Power. That should take care of the P0489.
P2089 is for a gas engine from what I’m coming up with. Are you sure that’s the code?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I just looked at a DIESEL website
P2088: A CAMSHAFT POS ACTUATOR CTRL CIRC LOW BANK1
P2089: A CAMSHAFT POS ACTUATOR CTRL CIRC HI BANK1
P208A: (DIESEL EXHAUST FLUID) REDUCTANT PUMP CONTROL CIRCUIT OPEN
P208C: (DIESEL EXHAUST FLUID) REDUCTANT PUMP CONTROL CIRCUIT LOW
P208D: (DIESEL EXHAUST FLUID) REDUCTANT PUMP CONTROL CIRCUIT HIGH
P2090: B CAMSHAFT POS ACTUATOR CTRL CIRC LOW BANK1 C)
Fuel35 67
Hanford
Out diesel 6.7’s do not have a cam control. That’s for gas engines. We have a cam shaft sensor, but no variable valve timing.
D
Dave Flomerfelt
6.7 diesel
Thank you Fuel 35-67 for your idea, now I just have to figure out how to do it.
