P1524 light keeps coming back
Matthew Smith
Georgia
I have a 2012 ram with the 5.7 I was kept getting the code , I changed oil filters and that fixed it for a while. Today it came back I checked the oil pressure with a gauge.
At idle warm it’s about 25 psi
At 1500 rpm it’s around 60psi
At 2000 rpm it’s 70ish psi
I’m at a list for what it could be at this point
I have done the mds delete and a hellcat oil pump and lifters.
I don’t hear and noises out of the usual, my truck is straight piped so if there was a subtle noise idk if I’d hear it
jws123
nj
did you replace the oil pressure sender yet?
The Hellcat pump has been known to give an oil pressure code on a 5.7 or 6.4. Hunt through Reignited Cycles video's he has a couple of fixes,one being to swap your original bypass spring into the new pump,but if the pumps installed that's probably not feasable,so you might have to try his 2 resistor trick,one other option a few guys have said they've had success with is to swap the hellcat oil pressure sensor in.
Matthew Smith
Matthew Smith
Georgia
Would you happen to know which video it is I can’t find that one
Search my name on here,i posted a link to the video not all that long ago. I don't have the time to look it up for you today until alot later.
Ok I appreciate it
Alans145
CA
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
You will have to double check this info :
Some owners are mentioning that the 899 oil filter uses the same gasket as the ones that were installed on the 2015 & newer 5.7L HEMI.
The cannister itself on the 899 is about 5/8ths inch larger
found on LX forum & others
MO-899 will also work on 5.7L although after 2014 the factory appears to be installing the smaller MO-339 filter on the 5.7L, the MO-899 still the factory filter on 6.4L and Hellcat. So you can use the 899 or if you go to the dealer they will probably give you the 339.
Feb 25, 2018
thoffmann517
