p300 not a simple answer 1996 dodge ram 1500 4x4
Discussion in '2nd Gen DIY' started by 96liftedram, Mar 27, 2017.
  1. 96liftedram
    96liftedram Junior Member
    Mar 27, 2017
    Ram Year:
    1996
    Engine:
    5.9 360
    Truck has had this cod since i bought the damn thing here's a list of what I of what I've done so far
    new tie rods
    linkage
    steerning stabalizer
    spark plugs
    wires
    oil change
    cap and rotor
    o2 sensors
    tranny flush
    transmssion filter gasket
    water pump
    oil sensor
    belt
    new timing chain
    timing chain gasket seal
    plenum gasket
    harmonic balancer
    intake gaskets
    valve cover gaskets
    pitman arm
    oil pump
    oil reciever
    new oil pan gaskets
    I've done all this on my off time over the last couple weeks just got the engine back together today and bam CHECK ENGINE light P300 :(
    Im going to check the catalytic converter and vacuum when I have more time
    Since I've put it all back together it runs like a monster, any imput would be great
    *** side note after I clear the code I can drive for MILES (30+) and the light wont come one its only after i turn the truck off then got to drive it again that it will turn up ( this happens everytime before and after the overhaul)
  2. yoda
    yoda Senior Member
    48
    288
    97
    Jul 25, 2016
    Ram Year:
    Engine:
    Did you do a compression test?
  3. Shadow_Death
    Shadow_Death Senior Member
    149
    12
    Feb 13, 2017
    Ram Year:
    1996
    Engine:
    5.2L Magnum
    What Yoda said and I noticed you didn't have ignition coil listed in there. Any idea how old that thing is? They are easy to overlook when doing a tuneup.
  4. dapepper9
    dapepper9 Senior Member
    22
    4,834
    1,868
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    P0300 as in multiple misfires?
Share This Page
