Paint care/polish prior to Ceramic coat
MEGAVITES
NJ
new owner of a Black 21 BigHorn/Lonestar Night edition. I've owned a black before but i know extieror paint polishes etc have progessed since the last time I had to do some cleanup on swirls or scratches.
I'm curious what others like to use to remove light swirl/scratch marks that I see in this black paint prior to adding cermaic pertection.
I have an orbital buffer and want to achieve the best deep gloss I can prior to ceramic coat. I think white pad/compound would be too aggressive.
I have black pads for polish and blue for ultra-fine polish/waxing.
What products do you like...especially for the Diamond Crystal Black pearlcoat?
aces-n-eights
Check out this thread...
The short answer to your question is to use Koch Chemie F6 polishing compound. If your are a DIY'er, i would highly recommend using Undrdog protective coating. Treburkulosis lists the steps to the process in the thread above. The steps he lists for my car included stripping off a previous coating and you will probably not need to do that.
jejb
NW Arkansas
There is a "Detailing" forum here that might give you more results.
