POS alarm just went off couldn't disable
Limeybastard
Shady Hills, Rednecksville Boro, Florida.
Just parked up and my alarm went off within seconds. I couldn't turn the alarm off at all, pressed the lock and unlock button a few times even got into the truck and started it and it wouldn't go off. What the hell is going on?
I think in the end it went off by itself. I was about to pull the battery negative was embarrassing.
Edit. I think I had to use the physical key to open the door as the keyfob button wouldn't unlock the truck. If that makes any sense.
Sent from my SM-N910T using Tapatalk
roastpuff
I bumped the panic button by mistake once before. The only way to turn it off is to press the panic button again - no other buttons work.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
With all your posts, what actually does work on your truck?
RR7_905RAM
Southern Ontario
2018 Sport
Same here but it took me a minute to figure out wtf was going on.
Pretty sure it was after 3 days of ownership so embarrassed ummm yeah!
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
What an arsey response, pretty disappointed with that coming from you.
Yeah, I guess it comes off that way. Was not my intent, just ribbing you. :)
Limeybastard
Limeybastard
Good to know, thanks. I didn't try that. But I did read the manual and it said something about unlock and lock won't work to open the door if the alarm is activated. But did say alarm should go off when sentry key or whatever it's called is used to turn truck on. It didn't as truck was on with alarm still going off. So I suppose it could have been ( hoping) the panic button being pressed.
clh1220
st Louis
I bet it was the panic button. I've done that and had to hit it again to get it to go off. I'm good at remote starting mine when the fob is in my pocket. I'm glad to see you old guys made up, LOL.
Limeybastard
Limeybastard
Yeah. Certainly looks like I'm the monkey in this post. [emoji12]
GreenClassic
Las Vegas, NV
2015 Big Horn CC
I've also set off the panic alarm when it was in my pocket. Like roastpuff said, the arm/disarm buttons will do nothing, you have to hit the panic button again to make it stop.
OasisNinjaBat
