Power Steering Pulley
zyn_enthusiast
Tennessee
2009 Ram, 5.7 Hemi
Is this pretty significant chip in my power steering pulley a cause for concern? And can a significant chip like this happen on its own or do you think it would need some force behind it?
Backstory: Had some engine work done recently where it required the mechanics to pull the engine. Honestly not sure if it was there before I brought it in or if it was one of the mechanics that damaged it. Since, I’ve been hearing squeaky sounds when I start the truck, that point me in the area of the broken pulley. Could this cause a squeaking sound? And is this a safety concern where I need to fix it ASAP?
rzr6-4
nebraska
When they were pulling the engine, assuming that they banged that pulley on something to cause the damage its possible that the pump bearing is damaged and causing the squeak. Possible but far from guaranteed. You likely just need to crawl under and spend some time listening (which you may have already done).
Assuming the pump itself is fine and the pulley is the only concern, as long as there are no cracks coming off of the break I wouldn't worry about a failure. Technically you will have a mass imbalance that could cause vibration but I doubt that would be noticeable.
Z
zyn_enthusiast
Tennessee
I have noticed since, at highway speed I get a bit of a vibration. Could this be the culprit?
And the squeaking sound only happens when for the first few minutes after I start the truck then goes away.
turkeybird56
Central Texas
Not gonna hurt as long as belt seats in there OK, but if it was me, I would replace. But that is just me. My thought being if idler pulley is worn, that belt may have a lil play. U may wanna have the PS pump checked also in case bearing got tweaked. Hard to know here ref Internet Guessnosis.
Z
zyn_enthusiast
Tennessee
The power steering pump is brand new. But the pulleys could be the source of the vibration at highway speeds?
RamDiver
Marlborough, Ontario, Canada
A squeaking belt at the start is quite typical of a belt that is damaged or too loose.
If the belt has no apparent frayed edges or damages, I would check the tension.
This vibration you mention, does it happen at a specific speed? I would doubt it has any relationship to the damaged pulley. Vibration at speed is usually related to wheel balance or driveline couplings.
Like tb56, I would consider replacing it unless it's horrendously expensive.
Z
zyn_enthusiast
Tennessee
It happens around 50-60 mph. I just got new AT tires, so maybe I just need to get them rebalanced. Thoughts?
RamDiver
That's a good place to start.
I would speak to the shop where your tires were installed but keep in mind the items below.
Some tire sellers are grossly incompetent when it comes to balancing wheels.
Many users insist on the use of a 'Road Force' balancing machine.
