power steering
tdills
I have a 1997 dodge ram 1500 sport. the power steering stopped working so i changed the power steering pump and that didn't help. then i changed the power steering gear box. and it still doesn't want to work is there anything that i am missing that i can try? thanks.
HolyRamBatman
Deep in the Heart of Texas
Welcome to RF.
When replacing stuff did you check your hoses for deterioration or blockage?
Did you bleed the air out of the system?
Is the belt tight?
Just a few question. There might be more.
T
tdills
Yes i checked the hoses and i put a new belt on a couple months ago. i just noticed today that when i start my truck and look in the power steering pump there is no fluid then when i turn it off there is fluid is that normal?
HolyRamBatman
No don't think so. If you drive it, it should foam up bad. You don't want that.
Put fluid in start it and turn your wheels from side to side. Go all the way till it stops each way. Keep checking the fluid level. Do not let it run dry.
When done top it off to the proper level.
T
tdills
So today I've done what you said and i even put new lines on just to be sure they weren't blocked and it seams to work until i put my tires back on and then its as if my power steering stops working again normal
HolyRamBatman
The weight of your tires will be noticeable but it shouldn't feel like you don't have PS.
Do your suspension parts look ok? Are you running big tires?
Try not to throw money at it unless you are sure it is the problem.
I'm kinda surprised others haven't posted.
T
tdills
My front shocks need to be changed and my tires are 35/13.50 and is it possibly i could have crossed my return and pressure lines on my steering box?
Orca
