Stangshcky12
- Oct 26, 2011
- 9,047
- 941
- Location
- Oshkosh, WI
- 2007
- 5.9 Cummins
I think your pressures are right where they should be
I saw people on other forums saying that the common rail can hold 29k psi fine but I couldnt find actual numbers just here say
Finally came across these
eBay Guides - The Bosch Common Rail Fuel Injection System
The Common Rail Diesel Injection System Explained
According to what I could find 2005 injectors are designed for 1800 bar which is 26k psi
You will hit your rail pressure relieve valve before you damage a injector. I couldnt find an actual number on that but hear say from other forums is 2000-2100 bar so 29k+ psi
I definitely wouldnt stack anything with your tuner now though, they call them pressure box for a reason haha
