Ram 1500 Broken Wheel Stud
Brad07RDR
Ontario
Is there any easy way of replacing a broken wheel stud? Any help greatly appreciated. Thanks! 2007 ram 1500
MADDOG
Out Exploring Arizona
They press in from the back and they are usually splined. So I'd see if a machine shop can press it out for you. Replacement studs are available.
BWL
Embrace the skeptisism
BC Canada
I had to slip the axle out partially to get enough clearance to put new ones in. Getting the old one out can be done with a hammer and punch usually. I'd get it mostly out while the axle is still in. The new one can be pulled in with a lug nut that isn't capped. At least that's how I did mine.
HemiLonestar
MD
I pulled the axle shaft out and took it to work with me (hydraulic press). Pressed old one out, pressed new one in, put axle shaft back in.
PrettyMolly
just hit up good ole Ebay and buy a hub assembly for $30-$40.. quick, easy, and painless.
Orca
