Ram 1500 tradesman tow hook install
Minnesota
I am wondering if I would be able to put front tow hooks in my 2013 ram 1500 tradesman/express, I looked under and see that there are mounting spots but just want to make sure before I pull the trigger, and obviously I understand I need to make cuts to the front of the bumper
OC455
Central NY
Just have to buy them and install. Your truck has the one piece plastic insert correct?
OC455
Central NY
I would check and see if you can find someone with a truck with tow hooks and measure the holes and how far away from the sides of the bumper they are, and make a template if you can.
LugsLeadOut84
NYC Suburb
Shouldn't be a need to measure.....I installed hooks on my '12 and the plastic insert had a pattern outlining where the hooks protrude. You just have to follow the outline and cut carefully. I used a utility knife and you'd swear they were factory installed.
Socalramfan
Huntington Beach
2011 Big Horn
Same thing. They are already marked, I used a dermal.
Socalramfan
Huntington Beach
2011 Big Horn
Not sure about that. The face of your trim piece does look like a little different design. Same size, just different markings. Start with small cuts and use a cardboard template :waytogo:
ulemon
Iowa
Have you seen this thread?
Orca
