RAM CARES and DRAG LINK RECALL !
Omegasupreme
Home
The "FIX" is full replacement if their is something to fix, like when the nut has become loose and worn the threads.
The weld is a preventative measure. If it wasn't loose or show signs of wear, it isn't broke so there's nothing to fix.
The supply chain is broken. That problem is everywhere and affects everything.
This is completely false. I have already spoken with ramcares. Mine is completely fine , yet the recall remains and is being shipped to my dealer.
Supply chain is broken for things made in foreign countries. It is not affecting everything. My local cabinet maker is pumping out more cabinets than ever.
jejb
NW Arkansas
Last time I went to the dealer to have an alignment and front end checked a few months ago. They ground off the spot welds but could not get the adjuster to move. Said it was $7xx for a new drag link since the recall only pertained to the nuts not the adjuster. Even though it would have only been $200 for me for my deductible. So for $100 more then the deductible I ordered the synergy drag link.
They're shining you on. The recall is for the drag link to be replaced. They can weld it once, but once that weld is removed (for alignment, etc), it cannot be welded again, per Mopar. The drag link must be replaced in that case.
White six four
Wisconsin
I've heard that but apparently isn't true at least not at the 2 dealerships by me. I tried getting both of them to replace the welded drag link. It had been rewelded at least 3 times. Neither of them seemed to want to work on a heavy duty truck. Either way I'm perfectly fine paying out of pocket for the synergy and not having to deal with that stupid poor excuse of a "fix"
Zoe Saldana
california
6.4l
Why are you having so many alignments? Could you have another front end issue?
I have a 2016 like you with 70K miles and I haven't had an alignment yet.
White six four
Wisconsin
Bought the truck used. Dealer put on new tires when I bought it. After 5k miles the outside tires were wearing more then the insides. Had it aligned.
Truck had 2.5" spacers front and rear with no adjustable track bar. Added an adjustable track bar which through the steering wheel off recentering the axle. Had it aligned again to get the wheel straight.
6 months later the upper ball joints were bad and the outside of the tires were still wearing a lot and starting to cup. Had the shop do another alignment after they replaced the ball joints. Then I found out about thurens alignment specs and realized why the outside of the tires were wearing like they are.
jejb
NW Arkansas
FYI, there is language in the recall that says Mopar may reimburse you for costs if you have the fix done yourself.
White six four
Wisconsin
I tried on their website but since it says the recall was completed it wouldn't let me.
Omegasupreme
Home
Man.. my dealership sucks. Ram west hills in bremerton is awful. half day to full day to do this plus an alignment. That is crazy. Dealer ships are a complete scam.
jejb
NW Arkansas
Try contacing RamCares here. When the welds were removed, the original recall was voided, so to speak.
In my case, the recall was done when I bought my truck used. It was 1.5 years in service, 14K miles and a certified pre-owned when I bought it. I ran through a set of new (but cheap) tires the dealer had put on in 7K miles, so got an alignment from an independent shop when I put good tires on it. They had to grind the weld off and would not weld it back on upon completion. Loctited and torqued.
I did more research on this and contacted RamCares about it. They told me it could only be welded once. So even though my truck had the official weld recall, they authorized the replacement. Took quite a bit of time and I had to keep on it, but they did replace and do another alignment.
So it might take some commitment on your part to chase it down, I believe it is doable.
White six four
Wisconsin
I contacted ramcares and had a case opened. They were supposed to call me and I guess did but it would show up as a spam call so I never answered and they never left a message. I would have thought they would have at least left a message. Oh well. No big deal. The synergy was only a little over $300 and I don't have time to be playing phone tag between ram cares and the dealership. Water under the bridge now. I'm glad ramcares took care of you and got yours replaced.
krakaman24
2018 Ram 2500 6.7L CTD
Colorado
CTD 6.7L
I paid for the Synergy out of pocket and put it on while upgrading the rest of my front end. Never looked back and never dealt with the headache of trying to get Ram to pay for it.
Don't get me wrong, I completely understand the principal of the issue and also think it is BS. However, spending the $300 or so bucks to have the problem fixed with no headaches on my end was my choice.
jejb
NW Arkansas
Completely understand. It's just a sad statement when it's so much hassle to get Ram to do what they are suppose to do that it's worth going hundreds of dollars out of pocket to fix it yourself.
Tom6363
Phoenix, AZ
2014 4x4
For those who've tried getting re-imbursed, show of hands who are original owners and those who are buyers of a used truck and not the original purchaser.
RamShark1
Los Angeles
I'm in that post recall spot welds broken for steering alignment(per dealer service tech direction) and then Dodge dealer declining to touch it now HOLE....
I decided to purchase the Synergy link from 4WP and have been waiting for the part since MARCH 19th....no joke, purchased March 19th online, 4WPs last told me I am at the top of a list of other customers nearly 100 deep.
Dealer service tech had told me to have the welds ground off by alignment shop, aligned and then bring to them to check specs and then reweld as part of the recall. But service tech changed his tone when he looked at the drag link post grind and refused to even put the truck on a lift......
I had to tighten the lock nuts again myself and then weld them myself to just be able to safely use my truck until the Synergy part came in.......2 months later.....still waiting!!!!
RamCare reached out to me back in March but I missed their message...so starting that convo now..... BUT HOLY CRAP, 2 MONTHS FOR A PART....
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Yep, welcome to the world post covid. Parts and supply chain issues continue to be a problem and are not expected to return to pre covid conditions until at least through 2023. Not good, but that's the reality.
Daw14
If you were to pm @RamCares they are now addressing this issue . Do not go through a dealer contact them by pm ,they are changing them out daily .
RamShark1
Los Angeles
I understand, grateful my family, friends and I are healthy, although we lost our mother during last year’s covid chaos in the severely challenged hospital environment. So waiting on a part is a minor pain not to overly sweat. This too shall pass.
RamShark1
Los Angeles
Having to wait since the March 19th purchase of a Synergy drag link, a company that seems to be located in Southern California, makes one start to assume Synergy’s manufacturing is in China, the country most effected right now with Covid shutdowns, or their material suppliers are. Anyone know where they manufacture?
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Sorry to hear that Sir and for your loss. My prayers to you and your family. This covid sure altered our world in many ways.
