Here is an update on my random extended cranking issue: I had the truck to the dealer multiple times for diagnostics, a fuel pump relay bypass, new fuel pump, crank position sensor, etc etc, none of which solved the issue. They kept saying all the engine and fuel readings were correct. I took it in one final time as requested by my Chrysler Customer Service Rep, and the dealer tech was able to locate an issue with the wiring harness at the accelerator pedal position sensor. Basically the harness was not fully closed, resulting in a bad connection to the accel position sensor. He detached the harness connector, added contact promoter, and reattached securely. I Have had the truck back for almost 2 weeks now with no recurrence of the issue. Prior to my last visit the extended cranking was happening 1-3 times per week. Hope this helps some others out there, but my particular case seems pretty isolated. Unfortunately it was a difficult diagnosis that likely could not be replicated or identified by the home mechanic.
