rear coil springs
Mradzik
illinois
Have a 2022 1500 classic, replaced rear coil springs with tuftruck 1211 and gained about 1/2'' of lift. Then i installed a Leer fiberglass bed cap and the rear end now sagged down to level. Once i put 200-300lbs in the bed, its really sagging. Any info on what other coils to try that dont ride like a one ton would be appreciated. Also, rear end leans to the drivers side by 3/4'', any fix for that?
pacofortacos
Something doesn't sound right, there's no way 1211's will sag with 200-300 lbs unless defective. When I had them on my 16, I filled the bed and had a trailer on and it maybe dropped an inch.
How heavy is the bed cap, I had an ARE fiberglass tonneau on mine?
Maybe you received a bad set?
pacofortacos
Yeah, that doesn't seem right.
Also, with my 1211's I actually lost a little height empty, definitely did not gain any.
Sounds more like the 1223's.
Were the coils all pretty evenly spaced or were a few closer together on one end?
M
Mradzik
illinois
Coils are evenly spaced like they should be for a linear spring compared to a progressive spring.
pacofortacos
Hmm. Unless that cap weighs a lot more than you are thinking.
I would contact tufftruck and run it past them.
With mine, I could jump up in the bed and it maybe drop 1/2" if that and I am over 225.
M
Mradzik
illinois
Can anyone tell he the height of a stock truck?? Measuring from the ground up to the center of the rear wheelwell. Maybe I did loose height with the new springs, I can't find my measurements I wrote down with the stock spring. I keep getting conflicting stories with the 1211 springs, some people get 1/2" lift and some people get no lift. I'm 275lbs and if I sit on the Tailgate, the truck will drop about 1/2". And this is with the tuftruck 1211 springs which are supposed to have a 50% increase over stock springs. I'm really starting to think I got a bad set.
rvance
Pent 3.6
Get some Air-Lift air bags. You should have done that first. I've had them on several trucks with no issues.
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
^Agreed. AirLift 1000 or 5000 depending on your usage. I'll be doing the 5000 on mine soon. Wanted to keep the compliant ride of the stock springs but help the truck handle it's 10k tow rating better
rvance
Pent 3.6
Yep, I put them on when I got the truck for pulling a trailer. I have a camper cover, a bed liner with an extra bed mat and a Ranch Hand bumper. I keep 16 pounds in it and it handles and rides great.
Billincamo
3.0 L Ecodiesel
I installed Timber Grove Air Bags in my 2022 Laramie. I have a 500# pop up camper on the bed. I also tow a boat or my Lance Travel Trailer (5,000#'s). Tongue weight is 500#'s plus 500#'s for the pop up camper shell is a total of 1,000's and dropped my bed several inches. The air bags now work flawlessly. I traded in my RAM 2500 for the 1500 Ecodiesel. I never looked back. The 1500 ride is 100 times better then the 3/4 ton.
pacofortacos
Mine was about at 39" give or take 1/2" - but I have an Outdoorman which might be a bit higher than many models.
Dean2
Near Edmonton
On my brother's 1500 we kept the stock coils and added air bags. Made a world of difference. Keeps it with the proper rake even heavily loaded and actually improved the gas mileage by about 4 mpg by getting the back end up and the nose back down into proper position loaded. Handles a whole bunch better too, especially with a trailer on, but still rides really nice. Airs them down to 5 lbs running empty, and airs up to get the right rake depending on load.
Cablespinner
Hopkinsville, KY
I replaced the originals on my 2015 1500 with heavy duty springs from Michigan Truck Spring. I have 2 toolboxes and it raised it over 2 inches and stopped it from rocking from side to side on rough roads at higher speeds.
grizzstang
Calgary, Alberta Canada
The TufTruck 1211's were not as stiff as I was hoping. I added a set of Sumo Springs (blue) to replace the bump stops just to level the rear when my trailer is hooked up.
My travel trailer is only 19' but I am not sure what the tongue weight is. Looking at the truck when I drop it on the ball it must be 2000lbs. :D
pacofortacos
The 1211's say 50% increase over stock - but which stock spring?
Even then it might only be another 500 lb. capacity or so, there's no detailed information that I have seen.
Administrator
Find a CAT scale and take the truck and trailer fully loaded over the scales, then drop the trailer and weigh just the truck. Use those numbers to calculate the tongue weight percentage. Move some weight around in your trailer till your about 12%, too much tongue weight isn't good either.
Of course readjust the WDH to restore the lost front axle weight and the rear axle is heavier than the front.
hemihustlin
Montreal
I would not hesitate to contact tuftruck customer service. when I did they were very helpful.
I have the 1210s and biltstien 5100s in the back. love the combo! once in a while I wonder if I should have got the 1211s but hey if I ever need more capacity they are easy to change
I measured mine and my buddies classic the other day in his gravel driveway
his cc 4x4 night edition was 39 1/4 in the back
my cc warlock 4x4 was 39 3/4 in the back
mine was about 1/2 higher in the front than his as well but I forgot the exact measure at the moment was 36 or 37 and a half
so much for the warlock 2 inch lift lol but I dont want it any higher in the back for now
gofishn
Iowa
hemi 5.7L, 345 cu in
just put 1211 in my 5th gen and they are performing wonderfully.
WDH was not even set up correctly, 4 inches too high, still handled the trailer in 50 mph Gusts and steady 20mph winds.
Got WDH set up correctly and donp;t even notice trailer is back there and less than an 1/8 inch off unloaded fender lip measurements.
39 inches is rear, fi I remember correctly.
Call Tuftruck they are super helpful.
somethign is not right with yoru springs.
M
Mradzik
illinois
Thinking of replacing my 1211 rear springs with a pair of eibach 1" lift springs and eibach shocks. Would I have to install a drop bracket for the panhead bar, or will I be alright without it??
