recalibrate speedo?
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
Once the lift and 35s are on my truck will I have to recalibrate the speedometer? It's a 2017 1500.
crazykid1994
If it's not running 35s already your speedo will be wrong. So I would say yes you will want to
AFMoulton
Nuevo Mexico
What's the best way to do this??
bryan28
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
AFMoulton I plan to ask the dealer if they will do it after they install the lift and put on the larger wheels/tires. If they're unable too I may buy a speedo recalibrator or take it to a shop that has the tool to do it. An offroad shop that changes gears, wheels and tires should be able to do it for me.
Moab_Rockstar
Lake Orion, MI
5.9L
The dealer should be able to change the tire size in the BCM. That's all you need, it should be good to go after that.
TerraNewf
NL, Canada
Glad this question was asked, I was wondering the same
Hemi_1340R
Indiana
Can the dealer change it for 35s I thought they could only do it for stock size tires ?
bryan28
bryan28
Tullahoma, TN
2020 Laramie CC 4x4
When i dropped the truck with the dealer for the lift install and to have the new wheels/tires put on he said he should be able to do it for me. We'll see. If not I'll go to an offroad shop that specializes in lifts and bigger tires and have them do it.
yillbs
Dealer can't do 35's, no matter how much you beg them. You need to get a speedometer calibrator form hypertech. Part number : 752501, Any offroad store can order it for you, it's about 200 bucks, but does some other semi useful things. That's what I did, and now I change it myself, can read codes too.
Hemi_1340R
Indiana
Can the diablo tuner change it ?
AFMoulton
Nuevo Mexico
So at my dealer now, and they do not recalibrate speedos
Moab_Rockstar
Lake Orion, MI
5.9L
If the dealer has a tech with development tool access, there is a tire circumference value that can be inputted manually. WiTech only allows specific tire sizes now, no longer allows a custom value. Lame :(
AFMoulton
Nuevo Mexico
Well that's ********! Wonder if I can find someone who can do it on the DL.....
zstampe
Why not just leave it... you're talking about a few percent inaccuracy is all.
PDXRam
Portland, Oregon
DiabloSport inTune can fix it (also on (2016/2017). But, it is as mentioned above a tiny fix that can cost a few hundred bucks (tuner) or around $100 at the dealer. I did it at the dealer
