2017 non auto 4wd. I have ran Redline 5w30 since new. Did the front and rear diff with Redline. Forgot to do my transfer case, but figured might as well do redline since the rest is.
So was searching on the forum for what to use and I mostly see C+ATF if using Redline. Well according to Redline's website under transfer case it states both are applicable, but shows MT-LV 70-75w GL-4 as for the Borg Warner. So I searched the forum only found info on the C+ATF and can't find much on the MT-LV. But if I'm reading the site right the MT-LV would the correct one?
From Redline:
Approx Refill Capacity: 2
Meet our newest addition to the GL-4 family!
For use in BorgWarner Transfer Cases
From Redline:
MT-LV 70W/75W GL-4 Gear Oil
