- Jan 23, 2011
- 18,512
- 1,787
- Location
- Trumbull, CT
- 2022
- 3.6L V6
wow ok so it was low on fuel when remote started. Mine probably does the same. Everyone unbunch your panties lol
It annoys me.
Cant it log the last recorded level, then read that before it fires up? I don't see why it has to start to read, then read and shut off. Its as simple as 3-5 lines of code in the ECU.
Guess that's a good thing about my aftermarket remote start.
It does whatever the F I want it too do.. haha
Then the truck wouldn't remote start if you filled it up after shutting down.It annoys me.
You can't have it do that from the factory though. Most people are pretty stupid. I had a customer telling me how he is pissed because he got out of his charger and forgot to turn it off and it was out of gas the next morning. The car should know to shut off he said.
LOL almost 30 posts. I was just trying to say its a stupid design (the shutting off).
It could be stupid, but at the same time, when the wife forgets to fill it up, you remote start it to go to work, and bam, out of gas. You run to the lawnmower, bone dry cuz you winterize. You panic, its cold, no truck, gas station is a mile away...you start walking, freezing your ass off, get the gas, make it to work 2 hours late, get fired, wife files for divorce, she gets the truck and the dog...
Ill let it shut off!
Great feature, so you don't pull a stupid and idle yourself at of gas, and all people do is ***** about it.
Come on guys.
You can get a full gas reading with the truck in accessory mode, so one would think the boot procedure for the remote start would be to cycle through accessory before starting to check all the sensors and see if they fit within the start parameters.
Seems dodge went with a "shoot first and ask questions later" type mentality.
Sorry, bad explanation. You are right, not accessory. You get it in the on position without starting it. But the fact is, you can still get a reading without starting the engine, so the startup process for the remote start should be able to cycle through that info as well.
