Remote start
Mperry58
Southern Indiana
This may not be the correct forum but my remote start has stopped working. I have a 2012 ram 1500 with the 5.7 hemi. I changed the battery on the remote and that didn’t help. Anyone have any ideas they can point me to.
Thanks for the help.
1999 White C5 Coupe
A check-engine light (with one or more stored trouble codes) will prevent the remote start operation.
A defective hood latch (showing the hood open when it is not) will also prevent the remote start operation.
Have you tried remote start using both fobs?
M
Mperry58
Southern Indiana
No I have only tried one so far. Thank you for the information.
Dean2
Near Edmonton
Also, in addition to the good info above, if your vehicle battery is below 12.3 volts remote start won't work. Are you getting any horn beeps when you try to start it remote. The pattern of those beeps helps tell you what the issue is. Your owners manual has the specific info for your year, I don't know what they are for a 2012.
Flip-er
Raleigh, N.C
2013 Big Horn 4x4
Dean2
Didnt know about the horn beep thing
Thanks for the lesson
M
Mperry58
Southern Indiana
I’m not getting the 2 horn beeps. Everything else on the remote works. Someone above reminded me to check the other key fob. It works. I assume it would be something wrong with the fob?
M
Mperry58
Southern Indiana
I think I found the problem. I took the fob apart and the contact pads, not sure if correct terminology, were pretty dirty. Carefully wiped those off and it now works. Thanks for all the help.
Dean2
Near Edmonton
The fact you were not getting even a single beep or light flash tells you the FOB isn't actually sending so glad the contact clean worked. .
M
Mperry58
Southern Indiana
Thanks for all the help. It stopped working again. Can you buy just the circuit board?
