RES to RER
dylanprobert293
prince edward island
i have a 2009 ram 1500, it came with the RES stereo head unit with uconnect. i got my hands on a RER navigation unit from another 2009 ram laramie. does anyone know how i can go about wiring this in, 2 of the connections plug in but on the RER unit there is a 3rd connection of wires. i tried just plugging in the 2 sections and i can hear there is power but nothing is working. i do not need the navigation, i just care about getting the head unit to work
jawzs2
South Jersey
You only need the two conectors, the third one is for the backup camera and\or rear seat video.
Uconnect with the RES would need a bypass cable for the microphone mirror, or just a separate mic - try it without the gray 10 pin connector.
Here's the pinout
Radio C1 - Gray 10 Pin
Hands Free (U-Connect)
1. 18LB/DG LEFT AUDIO OUTPUT
2. 18DG/LB RIGHT AUDIO OUTPUT
3. –
4. 18DG/YL MICROPHONE FEED
5. –
6. 18DG COMMON AUDIO OUTPUT
7. 18LB/DG MICROPHONE IN (-)
8. 18OR/GY SENSOR GROUND
9. –
10. –
Radio C2 - Gray 22 Pin
Audio
1. 18RD FUSED B(+) (I.O.D.)
2. 20WT CAN INTERIOR BUS (-)
3. -
4. -
5. -
6. -
7. 18GY/OR AMPLIFIED ANTENNA FEED
8. 18GY/LG LEFT REAR SPEAKER (+)
9. 18GY/DG LEFT REAR SPEAKER (-)
10. 18DG/LG RIGHT REAR SPEAKER (+)
11. 18DG/GY RIGHT REAR SPEAKER (-)
12. 18BK/WT GROUND
13. 20WT/OR CAN INTERIOR BUS (+)
14. -
15. -
16. -
17. -
18. -
19. 18DG/VT RIGHT FRONT SPEAKERS(+)
20. 18DG/YL RIGHT FRONT SPEAKERS(-)
21. 18GY/VT LEFT FRONT SPEAKERS(+)
22. 18GY/YL LEFT FRONT SPEAKERS(-)
Radio C3 - White 22 Pin
Rear-Seat Video Montior
1. 18GY/LB AUDIO RETURN 3
2. -
3. -
4. -
5. 18GY/BR VIDEO SIGNAL 1
6. 18GY/YL VIDEO COMMON 1
7. VDO-VIDEO SHIELD 1
8. 18GY/LB VIDEO SIGNAL 2
9. 18GY/YL VIDEO COMMON 2
10. VIDEO SHIELD 2
11. 18GY/OR AUDIO RETURN 2
12. 18DG/VT AUDIO LEFT 3
13. 18DG/YL AUDIO RIGHT 3
14. -
15. -
16. -
17. -
18. 18DG/TN AUDIO LEFT 1
19. 18GY/VT AUDIO RETURN 1
20. 18DG/WT AUDIO RIGHT 1
21. 18DG/LB AUDIO LEFT 2
22. 18DG/DB AUDIO RIGHT 2
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
does your current RES 130 have a phone button ?
Most 2009 Dodge Rams with the RES 130 did not have a phone button
A few came with the phone button, they were called RESs 130
I suggest that if you don't have a microphone, buy a normal microphone that will work with the radio & install it either on the "A" Pillar almost against the Windshield, or above your right eye & forward a few inches, against the overhead console & roof liner.
( the reasoning for those two spots, is the stock Ram rear view mirror microphones are not noise cancelling & they pick up the noise from the Blower Fan in the HVAC system & they also catch the cross winds if your windows are cracked open.
Ram realized this, just read the owners manual
It reads close the windows & turn down the fan
to use the microphone
There are videos on how to upgrade the radio from the RES 130 up to the RER 730 or RHB 730
here is an explanation, no video, 2009 - 2012 are the same
It does not upgrade with an OEM radio though
video radio upgrades step by step
good luck
