Test drove 2500 Hemi on Wednesday. Wasn’t a long drive but didn’t feel the need for air bags. Before I pull the trigger tho I will put it through a good test.
I’m leaning toward the lighter fiver I have in mind that’s around 11000 full with hitch weight of 1650 empty. That will give me 1300 on payload I can play with.
Do you tow any hilly or mountainous roads? I will be venturing upstate NY and PA.
Test drove with my brother and him and the dealer said that if I go for a 3500 I might as well get it with a Cummins. Especially if I choose the larger camper I want. Larger camper = more $$$ + Cummins = even more $$$. Ouch.
Depending on how much you load up with and the weight of your hitch you might be closer to max payload than you think. We carry a lot in our rig and the sliding hitch and adapters probably add another 250-300 lbs. Our empty hitch weight is only 1250 and the CAT scale indicated I had about 2300 lbs sitting in there (5100 rear axle total, about 2800 of that being the truck itself ) My rear axle rating is 6300 so that’s not an issue. That said, if you don’t load too much you should be okay with payload…close but not over with a 1650 lb hitch weight. We are in Florida for the winters but a very long trip last summer took us through some long climbs with head winds, especially in South Dakota. The truck was very stable and there weren’t any white knuckle episodes but I’d recommend not looking at gas mileage during those climbing periods Over-all I got about 9 mph on the trip and we’re going to do it again this summer if gas prices don’t go a lot higher.
Another factor, with all that weight my truck only dropped about 1 1/2 inches, staying pretty level. I agree with you totally about the added expense if you go bigger rig with a 3500 Cummins. Great package but it all boils down to how much you want to spend. Good luck, hope it all works out for you.
