Rough Country 6’’ lift paired with Bilstein adjustable shocks
Cmz2800
NC
would that work? I just ordered the RC lift and Bilstein adjustables. Would that shock be too short seeing it’s going into a lifted spring?
crazykid1994
which rough country 6” kit did you order? Their base kit reuses the stock struts and adds a spacer above the strut to get lift. If you ordered that kit you would be fine using the bilstein 5100 up front. The rear bilstein would be to short of a shock
Cmz2800
Cmz2800
NC
This is what I ordered (and I didn’t get the spacer). I thought that I could use the lifted spring and replace both front and back struts with the Bilstein. But then I realized that the spring would be too long.
Cmz2800
Cmz2800
NC
No one wants to play with me
crazykid1994
Well. You answered your own question. The bilstein are stock length hood for a 2.5” level. They will not work as a 6” lift strut since they are still stock length. The rear bilstein would be too short as well.
Tyler_h
Edmonton
Hey friend, going through something simular now, except I have a bds lift. I am having issues finding shocks, so I sent an inquiry to billsteincanada dot something.
They got me to measure shock length currently on my Rancho 5000x shocks which was 26.25" & 26".
I do have my tools and plywood slider box in the box.
Photo attached is what they recommended I go with for shocks.
Good luck.
Cmz2800
Cmz2800
NC
Thanks. Yes they told me that unfortunately they wouldn’t work but he offered a set of Fox coilovers ($1800).
